ADAMHU wrote:the DE head is much heavier than the E, it is far more complex..and porting the E head is much easier than the DE, after porting both of them, the E head IMO is the better head ....and the reduced valve train weight is also a big benefit.....
you put a big cam in a E head...and it wants to pull till it blows
see the very nice smooth power curve of the E engine with race cam... (green line) look at that torque curve...(ok not alot but a nice curve)
DOHC's are more complicated than an SOHC head by design. And typically they are heavier. But just look at the differences between the use of the surface area available in the top of the combustion chamber. Unless you go to some type of an oval shaped valve, it would be difficult to get as much out flow through the SOHC exhaust port as two of the DOHC ports. Not to mention, the spark plug on a DOHC sits centered where the SOHC has it right about where the other exhaust port on the DOHC would be.
Put a nice big cam in a DOHC and you'll have a nice torque curve as well. Only, higher up.
As far as porting, I would suspect you can remove more material from the SOHC head. The DOHC needs much less though since it's got a bigger overall opening in the first place. And the valve is still going to be the bottleneck.
And this is not to say SOHC moors are bad. But I only posted to state a case against those that say the SOHC motor can make more power. But I would still argue that the DOHC probably has a higher power potential based on flow potential.
