BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Mon Mar 07, 2011 6:02 pm
The best way to deal with old transmission fluid is to find a shop that can flush the entire contents of your tramission and refill with nearly 100% fresh fluid. Since you really have no idea when any of this was done previously i would find a shop that can do all your fluids, transmission, power steering, brakes, rear end and radiator. Flush all of these and replace with high quality synthetics at least Mobile 1 or Redline/Amsoil if you can find and afford the better stuff. This will go along way to getting that transmission and other parts to run another 100-200k before they die on you.
I would also look up any records that the previous owner had with what is already been fixed. If for example they haven't done athe value cover gasgets, knock sensors, coil packs, those are all probably coming and can be done at the same time you put in fresh spark plugs. Those are usually done at 60k but also should be done every 5 years too.
This can be a sweet ride but with that high of mileage don't be surprised if you have to drop 2-4k into in over the next year or two.
