where can i buy precision gear power brute? i went on there website but i guess i can't buy it off of there.evildky wrote:and honestly the viscous is almost like having an open diff, I'n not a fan, the precision gear power brute is a great buy at about $600 brand new it's as strong or stronger than the stock CLSD's found in the 88-89 300ZX but for used ebay price you get a new one, and it's fits his Z31 or your S13 so you can share it
bunk, a bud of mine got one after that rumor started, has everyone forgotten that the Z33 comes stock with an r200? and that quaiffe and cucco are still making r200 lsd's as well as precision gear, you can order then directly from precision gear, but be prepared to wait as they make them in lots, and if they don't have any now it might be a while before they make another run, you'll have to call them at alst checkRacinjitter wrote:FYI the power brute is NLA. The tooling was broken in a natural disaster. The compamy cannot justify re-tooling due to the low demand numbers of the r200 lsd.
The gears won't. You need the long shaft pinion. I'm not sure if the stock pinion in your diff will mesh with the ring gear from the 4.11. But the actual assembly should work just fine in the housing. You'll probably need different half shafts though.datsun5ten wrote:Off topic..
I bought a short nose r200 out of a R32 skyline with 4:11....
and i have my long nose open r200...
You all are saying the internals out of the 4.11 will swap into my Z31 long nose diff? I just need different half shafts? i need some verbal assistance with this please..
the LSD carrier will work in your housing, but as az zbum pointed out the gears wil NOT, you'll have to take the ring gear form your long nose carrier and put it on the lsd carrier then install that carrier into the long nose housing, if you are putting it into an S30 you can put the short snout carrier in complete using the kit sold by modern motorsports, or just fab your own adaptersdatsun5ten wrote:Off topic..
