Superdav »
https://forums.nicoclub.com/superdav-u314087.html
Tue Feb 04, 2025 8:41 pm
I have another thread about lights shorting out I finally took care of but now I got big problems.
When going over all the wiring after I found a melted piece of a fusible link I discovered the 2 and 3 injectors were wired together, checked it out and #3 doesn’t work, it’s not getting the ground signal.
So far..
Relay good, replaced it anyway
Fuse good
Injector itself good, swapped it out with one from other truck anyway (I have a 91 2wd with a scorched motor and found this 4wd I wanted)
Swapped ecu with one from my other truck
Checked all connections and couldn’t find anything noticeable
While working on it the fuel pump quit, replaced it with the one from my other truck (it was 2 years old) started right up, injector still dead and obvious from the idle, tapped and wiggled every connection I could find with it running, pump quit again and I put in a new one, injector dead said f-it went inside and let it sit for 4 days
Tonight I get home from work and it does not start, fuel pump is dead, not turning on, drained the fuel line and turned the key, still no fuel pump so I swap the ecu out again, nothing
After 3 fuel pumps and 2 ecu’s I think I can rule those out
I’m completely stumped and can’t sell it I’d lose too much money, right now it’s a $3400 yard ornament
Help?
Superdav on Tue Feb 04, 2025 9:08 pm, edited 1 time in total.
