what lines are these?
MikeMurphy
Car: Guess
Could someone pls have a look at what I have posted regarding two mystery lines?
http://northwestnissans.com/bo...20073
It seems simple enough but nobody seems to know! :mad:
MikeMurphy
Car: Guess
I have checked the FSM and copied a page on the link's link enclosed. The FSM doesent help me in this case =(
NISTECH
If in your crude drawing where you said your talking about #1 or in the picture you have labled "hot chick" That is your air feed to your idle air control motor and your FICD.
NISTECH
#2 is egr and canister purge vaccum solonoid.#3 is pcv port for fresh air intake into the valve cover.
180fan
Car: 89 fastback
NISTECH wrote:If in your crude drawing where you said your talking about #1 or in the picture you have labled "hot chick" That is your air feed to your idle air control motor and your FICD.
ha ha ha "hot chick" ha ha ha
MikeMurphy
Car: Guess
Thanks!@
btw, what is "FICD"?
NISTECH
It is a bi metal valve that when cold provides additional air flow to the intake as the car heats up an electircal current is supplied to it to close the valve once it reaches operating temp.
FICD= Fast Idle Control Device
It is the item circled in this pic
MikeMurphy
Car: Guess
Thank you so much! The help you are providing is amazing.
