octane booster is a scam if you are already running premiumMOB240 wrote:so whats the point of octane booster? its useless unless youre running high hp? oh and btw kamin i think i saw your car @ nicofest lol...did it have a denetsu decal on the rear quarter?
That's not really true. If you wanted you could bump up base timing on the stock ecu to take advantage of higher octane at LOW boost. That way you'll have extra power without extra boost. The stock RB25 low end power really picks up power when timing is added at the low end.FriedEGs wrote:I've used Sunoco GT100 before, but, I really had no use for such a high octane. Even though Japan uses 100 octane, it seems our cars don't really benefit unless you're boosting a considerable amount, like 400hp +.
Octane booster is a scam, it only adds an average .5 or so to the octane rating. If you really want the extra octane level mix toluene with your gas, of course research this before you just add a bottle of it to your tank.Kamin wrote:octane booster is a scam if you are already running premium
Octane is a measure of how hard it is to combust fuel.Sil240 wrote:Kamin how will runinng 100 octane gas mak you slower????
Octane is the measure of a fuels resistance to KNOCK. It's NOT harder for it to burn. IT's harder for it to PREIGNITE. You're talking like the stock ignition will have issues burning high octance fuel which is false. It's SLOWER to burn and that's why 1) you can advance timing and gain power 2) it can leave deposits if timing isn't advancedKamin wrote:Octane is a measure of how hard it is to combust fuel.
the higher the number the more energy it takes to burn. that means the harder your engine has to work to burn it. if 91/2/3/4 octane is knocking to a point where its unsafe you need to up the octane.
OCTANE DOES NOT EQUAL HORSEPOWER. i always love people who put race gas in cars that have NO need for it.
unless your road trippin and not boostingCarl H wrote:
moral of the story is: dont run anything less than 91.
