I use ICE paste wax. A lot of owners suggest Zaino, however you asked for ease of use. You can go with a liquid but I actually find the paste easier to remove. I use a microfibre wash mitt along with using a Mr. Clean system. I also use the ICE soap which seems to work fine with Mr. Clean.4drmadness wrote:Hey guys i finally deceided that i really need to clean my car. i was wondering what would be the easiest wax to use, tht takes less time, and what type of drying towel, and wash mitt shud i get. thanks
I use Stoner for the windows, never Windex which leaves its own film behind.08.black.G37 wrote:I dry my cars off with The Absorber. Also, you will find that if your Absorber is clean and well wrung out, it is the best thing in the world to wipe off the inside of your glass. Your windows won't get that film on it that you get if you use something like Windex.
If I had the time I would use Zaino based on the results I have seen. You better have some time to spend on the project however. Between ICE and Tech-Wax, I find ICE to give better results, especially from the ease of use point of view. But I find the paste version much better than the liquid. I use a spray on detailer for final finishing and also for doing the door jams.SteveTheTech wrote:I've got to be honest I love the results of Zaino products but they take hours of hard work to get the desired results. Then you get hooked, and the wax turns into your mistress and you become OCD like me.
Someone gave me a bottle of Maguires Tech-Wax and although it still needs hand application the results after some work are well worth it.
Which type of ICE did you use, the liquid or paste. I used both with almost similar results although I think the paste is slightly better.Road Ruler wrote:Another vote for ICE:
I slapped a coat of this stuff on last October. It went on way too easy so I thought it might not be to good but what a surprise.
The car has gone through a brutal Canadian Winter. Salt on the car most of the time and too cold to wash the car. In fact it only got washed about every 3rd week.
I washed the G last week and wow it looked good. The Ice was still there doing its job.
