what kind of USED top feed injectors for my rb25? any suggestions?
boxcutta
Car: 1989 S13 coupe
Well, just like the title says Im trying to find used top feed injectors for my rb25. but Im a bit lost,
1. are the stockers high or low impedance???
2.does anyone know of an injector off a usdm car that will work (aside from differences in cc's, im looking to go bigger anyway)
3. I know what your all gonna say "just buy new", well id love to but Im almost completely out of cash for this project and id like to see it run this decade (going on 2 years since it last ran as it is).
any help is welcome, thanks
Cjmartz2k
Car: Hunting for a '89 GTR now
Stock RB25 fuel injectors are SIDE feed and high impedance. I run top feed low impedance injectors on my RB25 because I also run a GTR intake/fuel rail with an adapter, and a GTR resistor box.
boxcutta
Car: 1989 S13 coupe
ya, Im running the greddy intake on mine so top feeds are the only way for me, thanks for the info.
anyone know if the 7mgte supra injectors will work?
wawazat8402
Car: 89 Sil80- RB25DET
The Greddy manifold works just fine with the stock fuel rail and injectors.
StricNyne
i am running rb26 inj and rail on my rb25 manifold, and i had to fab up some tabs to hold rail up
boxcutta
Car: 1989 S13 coupe
wawazat8402 wrote:The Greddy manifold works just fine with the stock fuel rail and injectors.
u know I've been told that, but so far I cant get anything to work, the rail mounting holes dont line up at all, and the injectors themselves dont seem to wanna go in, anything Im not doing right?
s13point5
Car: 89 240sx
im running the greddy IM with stock rail and injectors. i only have two of the bolts holding the fuel rail on. and the injectors go in fine BUT you will not be able to unclip the plugs while the rail is bolted down onto the IM. which means if i have to replace one injector, the whole rail has to come off
boxcutta
Car: 1989 S13 coupe
sounds like I need to try harder, and maybe fab a bracket or two..
thanks for all the help guys
wawazat8402
Ill try to get a pic for you tonight while Im in the shop.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
if you want to go with top feed injectors for an Rb you can use the same style as in a G35 or 350z....higher flow rate obviously...im running RC engineering 650cc's in mine...works like a charm...got from a G35 buddy of mine...
gomer23
Car: 1989 Nissan 240sx
s13point5 wrote:im running the greddy IM with stock rail and injectors. i only have two of the bolts holding the fuel rail on. and the injectors go in fine BUT you will not be able to unclip the plugs while the rail is bolted down onto the IM. which means if i have to replace one injector, the whole rail has to come off
I'll be putting on my injectors next week once I get my 1 missing isulator haha.
Sil240
Car: Nissan S13 "The One Cam Wonder"
S14 Neo Those 350z/G35 VQ35DE injectors you have are they High impedance or low impedance.I'm assuming they are high since you reccomended them to run on the RB25.
But I'm on the look out for some 550cc injector for my RB20. I can't seem to find any RX& injectors at least 6 of them.
Do you know how many cc's the VQ injectors are?
S14-NEO
Sil240 wrote:S14 Neo Those 350z/G35 VQ35DE injectors you have are they High impedance or low impedance.I'm assuming they are high since you reccomended them to run on the RB25.
yes they are high imepedence injectors... what style are you looking for high or low...i will check on the stock VQ injector sizes and get back with you...off the top of my head i dont know...but if i had to gues id day 310cc or so...i will find out for sure though.
S14-NEO
ok the stock 350z injectors are in fact 290cc...not 310cc...pretty close thogh for just guessing..lol
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Brian, hit me up
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
FIY You can take those connectors out, and single injectors. I've done it several times.
Use a pick, the connector pops out and slides out free. If you cant get the injector out and those clips on the Greddy manifold, you installed it wrong.
boxcutta
Car: 1989 S13 coupe
just so everyone knows, After a bit more tinkering I got the stock fuel rail to fit. thanks for all the help
