what kind of tools im i gonna need?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I finaly bought a sr20 but i have never done a swap before. What kind of tools are going to be nessecary? I already have and assortment of ratchets sockets, alan wrenches, jacks, jackstands, and some other stuff...and im going to rent and engine lift.
Any help would be greatly appriciated!!!:icesangel
quiksilvia
Car: 95 s14 se
i dont know of any thing else. but let me know how it turns out
BuudWeizErr
As long as you have a nice array of tools, you should be golden. Do you have angle sockets and a torque wrench? A C ring remover tool will be handy also, but not specifically needed. Try and get some jackstands too, it'll make working under the car and mounting the transmission easier.
Good Luck.
Onizuka
im going to have to get some angle sockets and a torque wrench. are "ac ring removal" tools expensive?
chrispy
Car: 1990 Nissan 240SX HB
hey j spec where you getting your motor from?
Onizuka
Daunt : )
BuudWeizErr
it's not an "AC ring removal tool," it's a "C Ring Remover tool." It's to take the C ring out to be able to remove the shifter. It'll also come in very hand should you choose an SSQV BOV (like I did).
I'm not sure how much they are, but it would have turned my 1 hour long C ring R&R into a ten minute job.
Onizuka
thanks for the info, ill look into getting one. I already got a old school Blitz BOV...
MikeS14240sx
Car: 98 Nissan 240SX
BuudWeizErr wrote:it's not an "AC ring removal tool," it's a "C Ring Remover tool." It's to take the C ring out to be able to remove the shifter. It'll also come in very hand should you choose an SSQV BOV (like I did).
Or you could just remove the 6 12mm bolts that hold the whole shifter in.
mike_do
daunt has engines in??
Onizuka
no but im on the list ;)
they should be at his shop march 20th
Tai Mai Shu
Thats my birthday!
matt240det
you'll need an engine hoist, and extensions, and tools with life time warrenties, cause you will brake them, and IMO an absolute MUST, well not really but you will thank me later is turbo sockets...i mean they say turbo what more can i say, except that they take off stripped nuts, and they are AWESOME also it would be wise to invest in a GOOD set of wrenches i have the snap on flank drive plus, they are expensive but well worth it, they grip about 10 times better than anything else, also some ratchet wrenches would make things easier...I'm a tech at a dealership, so i luck out, i got my engine hoist for free i have lots of tools and anything i don't have someone else does...:ylsuper
bp2ooo
i got 2 c ring remover tools. They came in a pack of 2, on of them has an angled edge to get into tight places. The other one is strait, It was only 5 dollars for both, they are really cheap. That was at menards, but i have seen craftsman ones as expensive as $20
