redtop91 wrote:But for a daily driver I wouldn't go much over 400.
Curious, this is my exact setup except with .64 turbo (love the fast boost) and i have 550s. I thinking about doing this exact setup, does the safcII tune pretty well with the enthalpy tune? If i were to do this project on my next setup (right now i'm making 350 without cams, hope to hit 370 @ 20psi when i get my 274s) would you use the same ecu/safc setup or would you rather just hitup a powerfc for $100 more?DrifterProdigy85 wrote:Since im a member making 400whp on stock block i guess ill be one to give my setup.
SR20DET Redtop GT2871R .86 Turbo (20psi 93 Octane, 24psi 100+ Octane)Deatschwerks 740cc Injectors Z32 N62 MAF Nismo FPR Power Enterprise Intake 20x6x3 FMIC w/ 2.75" Coldside & 2.5" Hotside Greddy Intake Manifold Greddy Turbo Elbow Greddy MX Downpipe Greddy Type R BOV Circuit Sports Turbo Lines HKS 264 Step 1 Intake/Exhaust Cams Greddy Rocker Arm Stoppers Megan Racing Exhaust Manifold Megan Racing Test Pipe GP Sports EXAS Spec D Exhaust Nismo Engine & transmission Mounts Power Enterprise Radiator Cap Walbro Fuel Pump (Hardwired)Enthalpy Tuned ECUApexi SAFCII
As far what size tires to go with. Ill be putting 275/50-15 Drag Radials on 15x9 Weld Draglite rims. Wheels will be a 0mm or +25mm offset and the fenders will need rolled and pulled to fit right. Without any fender work, you can probably fit a 235 or 245 tire in.
