Paper figures like curtain area are dependant on alot of things including port area, port shape, chamber size and shape, among other things.
If you want to find some realistic numbers for flow based on "curtain area" and n/a power, take a look at ford 4.6 dohc motors, especially ones with B heads. They have Very similar siamese ports and valve sizes/angles as the siamese port VH45. Their intake valves are a hair smaller than VH45 in diameter (1.45), and on PAPER, the "curtain area" would limit them to flow less than .400" lift.... but on a flow bench, B head siamese intake ports jump up from
[email protected]" to
[email protected]". All of the horsepower record setters are all running cams up even above .500" lift with porting and stock valve sizes. The record setters are also making over 400/400 n/a pump as well, so 400/400 on a ~4.5L engine isn't something you have to use boost to get.
so, don't base valve lift on just the paper number of "curtain area" based on valve size.
