Deltron75ARK wrote:Just wondering. First time going in there I'm gonna' test drive and check the car out, then if I really like it I am going to bring a mechanic with me to really check the car out. But anyone got any suggestions as to what I should ask the dealer, as in problems with the car and things like that? I remember someone saying the G35 had some fuel problems or tire wear?
Any advice would be helpful
Thanks!
Deltron75ARK
If no one has said it yet Welcome
15000 miles is almost a new car. In two years, I'm close to 46kIf the dealer can prove oil changes, tire rotation, Air Filter replacement and Cabin Filter replacement that is about it. Inspect the tires and remove the wheels to inspect the brakes. Test drive the vehicle, take it up to 75- 80 if you can on level pavement. If you take your hand off the stearing wheel there should be no pulling to the left or right.Insist on an oil change new oil filter, air & cabin filters before you take delivery. Ask for a wheel alignment also and make sure everything is in writing that the work was completed at no charge to you.
Enjoy
Telcoman
