boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Sun Feb 16, 2003 1:01 pm
If you're going to add that type of turbo, why not upgrade the fuel management as well (Ie injectors, AFM and eprommed ecu). You put that big turbo on that engine and start cranking on the boost, your entire fuel system will be on the brink (minus the fuel pump). But with that set up and stock AFM, injectors and stock ECU should yield you in the ballpark of 235-250whp!
