Zebrahead wrote:Don't expect more than 250rwhp with a T25 at max boost on stock internals (12-13psi). Still, running boost that high is detremental on the motor in stock form. You can run 9-10psi pretty safely, but you have to upgrade the injectors to run more fuel. With 10psi, I'd say you'd have around 225rwhp, that'd be good for a mid 13. Maybe low 13s with good tires, strong clutch and damned good driving.
Nick.
