What kind of oil do you guys use?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Onyxblue
Car: 1990 300zx n/a, 08 Versa SL, 07 Pathfinder SE, 08 Sentra
Mobil 1 5W30 every 7500 miles
bucksnort
Car: Versa S
Wally World 10W-30
Jemdawg
Car: Super Black Nissan Versa 1.8SL Hatchback
Royal Purple 5w-30, checked at every 10000 miles and changed if needed.
fjwagner
Car: 2008 Nissan Versa S et al
Jemdawg wrote:Royal Purple 5w-30, checked at every 10000 miles and changed if needed.
by check, do you mean a lab analysis of the oil or just looking at the color? The lab analysis is really the only way to know what the oil properties are. I sent analysis to Blackstone to pin down the interval on another car.
PS: I know that Royal Purple is expensive and typically used in high performance engines (hate to break the news, but the Versa engine is not high performance) , but my personal opinion is that there are plenty of other oils that are cheaper, also synthetic and are good for 10k plus. Fred
daan
Car: 08 Nissan Versa S base
I personally don't think it matters WHAT oil you use, just that it gets changed regularly. My Miata did 190K on whatever 10W30 was on sale at Walmart, and an Omni that I used to have was on its way to 250K using whatever was cheapest. As long as you change it every 3-4000 miles, and use GOOD filters you'll be fine. I think everybody here has a different opinion on this subject, I bet 50% of all posts on car forums are about oil change intervals.
fjwagner
daan wrote:I personally don't think it matters WHAT oil you use, just that it gets changed regularly.
fully agree!!! I personally think you can push your interval to 5 k with conventional oil with no problem with modern oils, but I think this is a subject that gets "over thought". I use ExxonMobil products just because I work for them; no other reason. Fred
Return to “Versa Technical Discussions”
