What kind of oil and coolant is best for the sr20det? (motor, transmission, LSD)
trust
I was looking around and redline has both positive and negative feedbacks. some say castrol gtx and others just say mobil 1 synthetic.
As for coolant, I dunno.
Luke
Engine - Mobil 1 10w-30 or 15w-50 in the summer.transmission - Redline MT90 75w-90 GL4Coolant, it doesn't matter, use a lower antifreeze mix in the hot (30% coolant, 70% water).For the rear, i just used Valvoline Synthetic gear oil but I don't have an LSD so it might be irrelevent.
rico05
Car: 1992 RMS13 w/ CA18DET
Engine: Mobil1 15w-50Tranny: Royal Purple 90WCoolant: Redline/Royal Purple "water wetters" + 1gal distilled water + fill with green coolant.
240DRFT
redline, mobil 1 and royal purple and good brands to get stuff from
Juujai
mobil no good but its cheap at walmart =). 20 bucks for 5 quarts about 4 bucks a quart. and synthetic lasts longer than dinosaur oil so its worth it. if you have the money redline or royal purple. amsoil in transmission, redline differential.
rico05
Unless you have a race engine, Mobil 1 is more than ok. I am paranoid and change mine ever 5-6 weeks tho
