i-Zer0 »
https://forums.nicoclub.com/i-zer0-u31987.html
Sat Mar 25, 2006 7:25 am
My G50 avg's around 23 mpg - this is combined a/c on/off hwy/street (the hwy is mostly bumper-2-bumper stop/go anyway) - w/ 91 AZ-not-so-great (so I'm told) fuel - usually Chevron or local - now.....listen up - I have a set of magnets on the fuel lines that go to the engine - usually a vehicle can gain up to 5hp and 2 add'l mpg's - I have installed magnets on over 20 vehicles [one was even carbureted] since I learned of it back in '99 - it doesn't matter what grade is used - a difference in performance can be detected almost IMMEDIATELY - the mpg improvement takes a little longer to determine [usually about a wk of consecutive 'normal' everyday driving] - the 'mechanicals' are: as fuel passes through the abrupt magnetic field created between the attraction of the two magnets, the molecules are broken apart, resulting in more complete burning of all of them (rather than just most of them) - the refineries only 'clarify' fuel to a point - but the abrupt magnetic field breaks the mol's up even more - the dif can be felt right away - also there is less 'carbon' residual as a result of such 'more complete burning' - the less 'black stuff' (carbon residual {or unburned fuel}) the fewer the oil changes, the less accumulation on spk plgs, the less cat. replacement (as they eventually become 'packed' over time w/ the 'black stuff', resulting in costly replacement (ever try to pick up a used muffler? They are really quite heavy, compared to new, well this is why) - the less buildup in EGR circuitry (the valve gets stuck open/shut because this 'black stuff' gets in the way of the movement {which is very minute anyway} resulting in a car not starting up when you just shut it off on a warm day, or just idling way way too high) - the less of the oxy-sensor getting 'coated' w/ the 'black stuff' - the less (if not non-existent) 'sludge in the pan' - you get my point, the car feels as if it slightly turboed or something, it's phenominal - when you accelerate from a stoplight, the car just keeps going faster, and faster and faster...you have to back off the accel. pdl from normal because of the complete burning process - it doesn't eliminate all carbon, but it does most and is very noticeable - Just goto Home Depot and get the magnets that are rectangular [approx 3"x1"x1/4"] for about $2.97 - then get a small C-clamp to hold them on the lines so that they don't vibrate off - you will not only feel the engine 'actually breathe', but you will also see better mpg than what you are getting now... any vehicle, any year, any fuel-delivery configuration! I make no disclaimer, because you will see/feel for yourself - also the gov't (EPA) has done extensive testing in the early 80's - it's just another life-preserving secret that either they and/or the auto makers themselves are aware of, but not saying anything about - otherwise people's cars would be less expensive to own and would definitely last longer than they do or have, imho!
