SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Wed Jan 21, 2004 7:14 am
The mods should support this turbo. Basically the mods you listed (aside from a few you forgot) should be able to tide you over easily. The 3037s has a T25 flange so its a bolt on, but the oil/water lines need to be redone. Some custom work might need to be done on the turbine side. And you will need to get an external wastegate fitted. Depending on the trim, all the 30 series turbos will probably be lagging more than you would like. Keep that in mind since this is at the end spectrum of a sports turbo.
