What kind of Headlight Bulbs are in the Rogue?
rjchoops
Car: 08 Rogue SL AWD
EddNog wrote:
The only option that I know is guaranteed brighter is a plug n play HID kit, bulb type H11. I recommend ~4300 Kelvin temperature range so it looks like OEM HIDs (crystal white).
-Ed
Thanks, ED, so where can I find these bulbs? Do the bulbs unplug from the back uunder the lens or do you remove the lens from the front?
EddNog
Car: 2008 Nissan Rogue SL AWD
You'll need an HID plug n play kit, which includes bulbs and ballasts. The ballasts mount under the hood externally from the lamps, some place behind them to something secure. Then what you do is you unplug the factory bulb harnesses from the back of the headlamps, unplug the factory halogen bulbs, plug the factory harnesses into the ballasts from the HID kit, plus the bulbs from the HID kit into the ballasts, and then install the HID bulbs running out of the ballasts into the headlamps from behind, where the factory harnesses mount.
-Ed
rjchoops
ED, what kind of bulbs do you have in your Fog Lights? They sure look like a bright White light. Randy
EddNog
rjchoops wrote:ED, what kind of bulbs do you have in your Fog Lights? They sure look like a bright White light. Randy
They're bright yellow, but the auto-white balance on my camera, plus the overexposure, made it come out white in the pictures. I have 3200kelvin HIDs.
-Ed
mlmcgahee
Car: 2010 Nissan Altima Coupe S 2.5
I ordered and installed a set of Nokya H11 Cosmic White Magnum 80w_5000k. They have the HID look and the set was only $31.99 from Amazon.
http://www.nokyausa.com/cw/cw8018.html
They also have the Hyper Yellow in a H11 blub.
http://www.nokyausa.com/hy/hy7618.html
Tony_Ringo
Car: 2008 ROGUE S *Phantom White
Ummmm factory is 55w, does the stock harness hold up to that wattage?I am debating going with PIAA since they have been a long reliable company as far as lighting goes
mlmcgahee wrote:I ordered and installed a set of Nokya H11 Cosmic White Magnum 80w_5000k. They have the HID look and the set was only $31.99 from Amazon.
Goblin
Car: 2008 Nissan Rogue SL AWD Premium Pkg.
I'm not a fan of modifing the existing wiring to upgrade to HID. I did this once in NC and got busted on the yearly inspection. They made me put all orginal equipment on before passing the vehicle. Needless to say, I have not modified my lighting since.
I am however a big fan of Sylvania Silver Stars and highly recommend using these bulbs, as they will not affect inspections. Here's a link to themhttp://www.brightheadlights-hi...r.htm
mlmcgahee
Tony_Ringo wrote:Ummmm factory is 55w, does the stock harness hold up to that wattage?I am debating going with PIAA since they have been a long reliable company as far as lighting goes
No problems so far... I've had them about 2 weeks.
mlmcgahee
Goblin wrote:I am however a big fan of Sylvania Silver Stars and highly recommend using these bulbs, as they will not affect inspections. Here's a link to themhttp://www.brightheadlights-hi...r.htm
Sylvania Silver Stars do not come in an H11 blub which our Rogue's use. I have very bad luck with Sylvania Silver Stars on my wife's 06 Altima and my 03 Xrerra. They blow out after about 6 months. I did some reaserch and thought I would try the Nokya Comsic White. I am very pleased so far.
roguester
Car: 08 Nissan Rogue SL AWD
06 Nissan Altima S 2.5 Special
H11 is the same as 9003
philipa_240sx
And not just Silverstars... I used some Sylvania XtraVision's on my fiancee's Mazda and they were blown within 9 months. There is a price to pay for that extra light.
mlmcgahee
roguester wrote:H11 is the same as 9003
From what I understand the 9003 has to be modified slightly to be able to lock into an H11 socket....
I read that someware so I may be wrong.
roguester
oops totally different 9003 is a dual fillament hi/low, bulb H11 is single
jbbrooks6
Car: 2007 Maxima 3.5SL
Hi I'm relatively new to the Forum thing but i have a quick and hopefully not to hard question for you. We are about to buy the 08 Altima SL w/ Connection and Tech Package but it doesnt come with the Xenon Lights. I want them to be the same tint as the ones in the Rogue SL, What Bulb type and Temp woud i need to get.
confused.. i am not sure if this is a relevant wuestion but i noe someone who just traded her BMW and i really like the Tint on those... What is the Stock Temp for the BMW 335i's
EddNog
jbbrooks6 wrote:Hi I'm relatively new to the Forum thing but i have a quick and hopefully not to hard question for you. We are about to buy the 08 Altima SL w/ Connection and Tech Package but it doesnt come with the Xenon Lights. I want them to be the same tint as the ones in the Rogue SL, What Bulb type and Temp woud i need to get.
Factory HIDs are always in the 4200Kelvin-4500Kelvin color temperature range.
Factory low beam bulb type for all non-HID Rogues is H11.
-Ed
roguester
I just had hid's intalled 6000k with slim digital ballasts they look awesome.The hardest part of the installation was getting the HID bulbs to fit. The original halogen have metal tabs, the hid bulbs came with plastic tabs and they woudn't fit. I had to do some trimming to the plastic tabs to get them to fit
Venom_Rogue
-Techone 5000k H11 HID Kit
mstrmstr
Car: Venom Red ROGUE 08...and 4 others
stinky240 wrote:I putting in an aftermarket HID kit for the headlights and need to know the bulb type. What king of bulbs are used in the fogs? I may get a kit for the fogs as well.
RE: FOG LAMPSI am doing the 80/100 watt Xenon gas filled HID H-11 as a compromize.Just need more than the lame 55 w factory bulb
RE headlamps- high beam changeout.. I have the factory Xenon system and LOVE it.. by comparison high beams suck so I am looking to upgrade to a better HID bulb.
Questions.. How do you get to the Fogs to change bulbs(what body panels need to be removed) and how?)Question 2. What upgrade for high beam bulb would give me more reach on lonely nights, by myself, on the road???Question 3. Who has those neat body bolt removal tools since NISSAN decided to make it not easy for the DIY guy?
I don't like the Blue 6000K or higher look since it really looks grey to me.prefer 5500 and YES it makes a visual difference to me. Dang astigmatism and related blue visual impairment.
We need to start a project sticky for most DIY projects.
EddNog
1) There are flip down panels ahead of the front wheel wells, underneath the car/front bumpers. You access them from under the car, right behind the lamps.
2) I went with Toshiba HIR bulbs, but they're, "only," about 20-30% brighter, and the same color as stock.
3) Not I, I do without.
-Ed
mstrmstr
Thx Ed.. saved me grief..
Elton Noway
Car: 2009 Rogue SL FWD Phantom White Black Cloth
Hi Mcgahee... just wondering about the Nokya Cosmic whites you installed and how they are holding up. Due to the your experience with Sylvania Silver Stars I've eliminated them from consideration.
So... as I understand it, the Nokya Cosmic whites you linked to, (because they are H11), are just a standard bulb replacement... but only if you have the factory HID's. Correct? No wiring modifications etc.
Modified by Elton Noway at 10:54 AM 6/20/2009
Leo2005
EddNog wrote:
Bababoosky wrote:Can you drive with just the parking lights and fog lights on? Like the 08 MDX? I have always loved the way that looks coming down the road. Eddnog, where did you pick up your kit, online or local? I am in lower Westchester.
Can't be done if you rely on the factory switchgear, because the fogs won't light when the lowbeams are not activated. If you use a separate switch somewherre you could, but the cut off is much too short, so you'd have to drive really slowly, so it's still not very practical at all. They're fog lamps and have a fog pattern, not auxiliary/driving lamps.
-Ed
Just installed my new fog lights with premium digital v-hid kit. The power source is straight from a battery throw relay. I used mini led switch with bosch relay by connecting to a cd player 12v switched so I can turn them on at any time without headlights. At the same time they are off if the car is off. I used this diagram for wirings:
I don't have factory switch for fog lights but a lot of people on forum for m35 are asking how to rewire the original switch to light up them independently and I'm sure it's possible.
TRANCEBOY
Car: Rogue SL
I SEE YOU ALL MENTIONED THE HIGH BEAM/ LOW BEAM AND FOG SIZE
BUT WHAT SIZE IS THE BULB THAT BLINKS
I HATE THE ORANGE
AND WOULD LIKE TO CHANGE IT FOR A STEALTH BULB WHICH WOULD BLINK ORANGE BUT WOULD LOOK SILVER
PLEASE LET ME KNOW
philipa_240sx
Tranceboy,
TYPING IN ALL CAPS IMPLIES YELLING.
Please use lower case letters.
To answer your question:
The bulb sizes are listed in your owners manual on pg 8-26. The turn signal bulb is an S25. The 'American' equivalent is #1157.
Use this guide to find the bulb sizes used on your Rogue:
http://www.sylvania.com/ConsumerProduct ... efault.htm
TRANCEBOY
Car: Rogue SL
my bad
thanks for the tip
gonna get the silver covered turn signal lights
to get rid of the orange
ThandaPani
Car: 2010 Rogue SL
Installed a aftermarket HID Xenon 6500K. Looks pretty nice. I was glad to find two empty spots for my Ballasts also. Will post some pics soon. Next project, Fog light. But the OEM stuff is so darn expensive..
Halfbakedbat
Car: 2009 Nissan Rogue SL
I am looking at 35 watt plug and play kits for lows and fogs. Do I need error code cancellers
sngo1212
Car: 2011 Nissan Rogue SV Edition
Does anybody know where to place the HID ballasts for the foglights? Will I need to remove my bumper to mount them on somewhere? Or do you just use mounting tape for them? Let me know ! thanks!
TaiLuu
Car: 2009 Nissan Murano LE AWD
2011 Nissan Rogue SV AWD
2014 Nissan Pathfinder Platinum
I'm tired of the OEM lights on my rogue.
Is there a bulb that shines bright white?
I Heard of philps light something has pretty bright and white lights.
I don't want HIDs i don't want to buy a ballst.
07phil
Car: rogue sl awd 08
just buy hid 4300k kit... what's best place to put ballasts? Any mods to original beam?
thanks!
Return to “Rogue Forum”
