Using higher octane gasoline on an engine designed to run optimally on 87 won't be detrimental to the engine - just your wallet.angel0119 wrote:so your saying that i should used 87 on my 09 versa hb because i been useing 93 is that bad should i down grade??????????????????????
Higher octanes don't really help with economy engines or engines that aren't designed for them. It'd be bad if you had a Z and were using 87 instead of 91/93.angel0119 wrote:so your saying that i should used 87 on my 09 versa hb because i been useing 93 is that bad should i down grade??????????????????????
