What kind of fuel pressure gauge?
onecrazyfoo4u
Car: 03 Type S
I need to get a gauge to check out my fuel pressure, I know it's way rich right now. Does it just mount inline between the filter and fpr? What gauges are you guys running? I can't find one that includes an inline T to mount right up, they all say they bolt onto the fuel filter? What kind can I get that's cheap and will bolt right up? Thanks!
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
http://store.summitracing.com/...w=skuand http://store.summitracing.com/...w=sku
That will install between the filter and the fuel rail. Also be sure to read your other post.
onecrazyfoo4u
Car: 03 Type S
Sweet, that T fitting is exactly what I was looking for.....so that'll work with pretty much any gauge huh, as long as they're 1/8 in.? And it's 3/8" fuel line inbetween the filter and fpr right? Thanks a million!
cheapscheisst
Car: 1996 240sx w/ Kouki front end
go to home depot, buy a seven dollar pressure gauge, a brass tee fitting and nipples and stick it in between the filter and rail.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
bm racing. works good. i hooked it up right after the fuel filter. i have a digital inside the car by cyberdyne. t'd in at the same spot.
doridori23
Brass will leave deposits in the fuel system but for short term use (<10k miles you'll be ok) also most Home Cheapo gauges are not glycerin filled and this makes them very susceptible to vibration. The summit or any performance auto shop gauge will be glycerin filled to increase its durability.
onecrazyfoo4u
Car: 03 Type S
cool, thanks for the info guys. I'm gonna go check at autozone to see if they have a cheapo liquid filled one, if not, I'll order it off of summit.
