what kind of fuel computer do u guys recommend for use with sr20det's
luv2spedup
Car: 89 silvia
just wondering what kind of fuel computer do u guys use with ur SR's any suggestions and one more thing can i use a "MAP ECU"(power house racing manufactures it) with my SR20det cause MAP ECU works wonders with twin turbo supras
powerls
Personally, I'm a fan of the AEM plug and play units. They can control so much and they are pretty easy to tune.
VERGE
Car: Snow skiing, Track days
Power FC works really well and the hand controller can also display 8 different parameters. has a mode which shows the operation of sensors and switches too. If you want to go to a MAP type setup then you can get the Power FC D-Jetro model. With an adittional kit it can also provide electronic boost control.
highmilehatch
Power FC plus datalogit works extremely well for me.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I love my Greddy emanage. There is some myth on here floating around that it can only handle 550cc injectors which is a joke. Its says it can handle injectors 150% larger than stock. Not 50% larger, 150% larger, or 925cc injectors in the SR's case. It does everything a standalone does and only cost me about $500 with the plug-and-play harness and a free laptop from a friend. It has throttle vs rpm fuel tuning, ignition tuning, additional injector capability, real time display, data logging etc etc etc....
proimport17
Car: motocross, baseball
I'm glad you mentioned that about the injectors because i had heard that and had decided not to get the emanage because of that. It seems to do everything the big boys do and sure costs alot less. Maybe time to rethink it.
chillmieste
Car: 97 240sx KA-T
I use the emanage also and I love it. I think its the next best thing to a stand alone computer. Ebay is the greatest:)
nonvtecaccord
J-Spec Tuner wrote:I love my Greddy emanage. There is some myth on here floating around that it can only handle 550cc injectors which is a joke. Its says it can handle injectors 150% larger than stock. Not 50% larger, 150% larger, or 925cc injectors in the SR's case. It does everything a standalone does and only cost me about $500 with the plug-and-play harness and a free laptop from a friend. It has throttle vs rpm fuel tuning, ignition tuning, additional injector capability, real time display, data logging etc etc etc....
Your say you have a plug and play harness, where did you get this? Greddy website doesn't have vehicle specific harness on it. And my one suplier doesn't think they have any.
