what kind of cams are compatible with RWD sr20det
luv2spedup
Car: 89 silvia
i was wondering if cams from a FWD sr20det can be used on a RWD sr20det
Cyberkreig
Car: 1993 Nissan 240SX SR
I dont think so, if for no other reason than a fwd cam cant be adapted to spin a rwd distributer/cas.. and vice versa.
luv2spedup
Car: 89 silvia
thanx for the info bro
Teamsprock
Car: 1995 S14.5 GT3076R powered Built SR20det
Actually the FWD cams and RWD cams are interchangeable, all you have to do is switch the Dowel pins on the Exhaust cam, the RWD Dowel pin is longer, but you have to use the RWD cam gears! Most machine shops will switch the Dowel pins for free or really cheap! I have a FWD cam in my car due to a broken cam! Lots of people have done it, its simple! If you have the cams out you will know what dowel pins I am talking about, the one that lines the cam up with the Cam sprocket.
luv2spedup
Car: 89 silvia
yo man thanx much. actually i've been wating for hks 264s but its been in back order for months now and a friend of mine has 272 with him but as u figured they are for FWD thats why i wanted to know if they are interchangeable
Cyberkreig
Thank you for the correction. I had no idea that was possible.
Teamsprock
I found out the hard way because my cam broke somehow when installing it so I had to find out quick and used my friends FWD cam. The intake cam you shouldn't have to change anything, just the exhaust cam dowel pin. Glad my mistakes can help others ha ha!
Nismo_Freak
Car: 89 Nissan 240SX
Just FYI.
The SR20DE engine in the B13's have a hotter profile than our stock DET cams. This could be a cheap upgrade, as they have been proven to gain 6whp on the DE's.
luv2spedup
Car: 89 silvia
thanx guys i really appreciate the help
