WDRacing wrote:There are only 2 different valve cover gaskets. One for the SOHC and one for the DOHC motor. What year is your car, is it a single or DOHC. You can tell by counting the cams you see when pull the cover. 2 = DOHC and 1 = SOHC.
WD
there's 1 for a sohc, 1 for a early dohc(91-93, maybe 94) and 1 for 95-98(95-98 valve cover gasket has bigger holes for the bolts(the bolts are bigger on 95-98 than 91-94), it has an extra hole between the last 2 corner bolts).
the xterra's have different accesory(power steering, a/c, alt) design, so if its an xterra motor, you could prolly find out that way.
