brc19761 »
https://forums.nicoclub.com/brc19761-u245639.html
Sun Jul 05, 2015 11:39 pm
I have a 1994 Pathfinder LE v6 with 92,000 original miles on it. I drove the truck last Wed. and Thursday about 200 miles both hwy and in the city. The a/c performed perfectly as usual. I get in it Sat. to go to a 4th of July cook out and the a/c just blows hot air. I have the push button auto a/c controls. I pushed the a/c button on and off and I could feel the compressor kick in, but no cold air. I turned around and came back home. I went to check everything out more closely today. The magnetic clutch is not engaging at all. I closely read the HA section of the factory service manual. I checked the a/c radio fuse. It was not blown and radio works fine. I checked where the a/c relay goes with a test light and it is getting power. I also switched the blower and a/c relay and the a/c relay worked the blower. I did unplug the ac connector and the magnetic clutch connector and tested it with the test light and neither would light up. I know I need a 12v multi reader to check the a/c, clutch, and thermal protector to see if each one is getting 12v. I looked everywhere in my shop and could not find my 12v meter. But like I said I did check them with a test light and nothing lite up.
Next, I removed and disconnected the push button a/c and heat controls. I put in a back up control panel I had and everything worked on it. For, example it changed the air flow, it changed the blower speed, but I pushed the a/c button and the clutch would not engage. I noticed that all of the relays except the a/c relay would get warm.
If the Freon gets low will the clutch not engage on the compressor? I know the r-12 or either r-13 (I can't remember which # it said on the a/c lines) you can no longer get unless you have a license. So, unless I convert the system to a 134a and have a vacuum pulled and put new 134a I cannot see if adding Freon will make the clutch engage.
Does anyone know what else I could check or what else it could be if the clutch and compressor was not getting power? Can you buy just a a/c clutch or do you have to buy the whole compressor? If the system is low of Freon will the clutch still engage?
I would like to try and diagnose the problem myself b/c if I take it to a mechanic it could be tons of money that I do not have right now b/c I am in the process of buying a home and moving.
Any information would be appreciated.
Thank You,
brc
