heres my 91 s13 coupe that i bought in march, spent most of its life on jackstands (bout 3 months or so). i just got it registered last week, and now im selling it , but its for a bigger and better car its european, v8, rwd.... you guess. anyways, this isnt a for sale post. just showing my work. i will post the before pics of when i first got it. it was horrid. i completely stripped everything off the car. im at work right now programming a harmony remote LOL. later guys!
s14 obd2 74k mile ka24de out of an auto
s13 5spd manual transmission (mileage unknown, but shifts perfectly fine)
SPEC 6 puck sprung clutch
resurfaced flywheel
FRESH turbo custom built by Charlie Brown @evergreenturbo.com (garrett t3/t4 .63a/r 4bolt stage 3 exhaust with clipped blades, and .60 comp)
AEM uego wideband O2 gauge
autometer 52mm sport comp vac/boost gauge
autometer 52mm sport comp oil psi gauge (0-100psi)
Mazworx silicon couplers and T-bolt clamps ($$$$$$)
Bee*R 3'' N1 exhaust
megan racing 3'' test pipe SS
megan racing SR 3'' downpipe w/flex SS
IAP 2.5'' mild steel black heat wrapped downpipe from turbo
IAP equal length tubular mani (mild steel)
Tial 38mm wg w/3.5 psi spring
Zinda black wrapped dumptube
Zinda 2'' mild steel mandrel bent charge piping
greddy type RS blow off valve
24x12x3 FMIC (bumper support still completely intact)
Zinda 3'' aluminum intake with K&N cone filter
8:1 vortech FMU
walbro inline fuel pump
Zinda motor and transmission mounts
Zinda aluminum vacuum manifold
Zinda oil plumbing (gangster *** setup... all stainless braided AN fittings, no cheap brass here)
greddy profec B electronic boost controller
Blitz fatt turbo timer
battery relocated to back (clean)
blow through stock maf setup
ALL new gaskets and seals everywhere were replaced except headgasket
OEM plug wires, cap, rotor
NGK bkr7e11 plugs
water pump
z32 fuel filter (BECAUSE ITS CHEAPER)
altima dual electric fans w/relay
russell speed bleeders
NEW windshield + wipers
15X7 +0 Work Equip knock offs (gold center, polished lip)
205/50/15 falken azenis rt615 (STICKY!!!!)
cut springs (like that when i bought it)
pioneer old cd deck
alpine type S rear speakers (6.5'')
all new fluids and brakes
