are you sure its not 180kph?skaterpunk240sx wrote:where did you get the 180 mph speedo?>???
no... but the harness is like 15 bucks. i got the HKS harness on mines. works fine. some people think you have to have the same brand harness, its not true... just make sure its for your chassisskaterpunk240sx wrote:does it come with harness?
he probally did the convercion, theres a write on FAadrians_s13 wrote:are you sure its not 180kph?
hmm... i'd have to look that up. sheesh, i'm scared to go past 120, let alone 180vutony wrote:
i dont know if you have the speed cut or not but when you are racing and you get to the 125 or wever it is and you just bog it sucks loladrians_s13 wrote:hmm... i'd have to look that up. sheesh, i'm scared to go past 120, let alone 180
well, i remember the govt. limiter on my old ka sucked balls... it would almost completely close my throttle. but on my sr, i can stay going at 5k on 5th gear and not have it bog or anything... like i can keep my foot on the pedal and it would just go at that speed...skaterpunk240sx wrote: i dont know if you have the speed cut or not but when you are racing and you get to the 125 or wever it is and you just bog it sucks lol
Its most likely the 180mph speedo from LS-Autohttp://lsauto.com/products.aspvutony wrote:
http://www.zeroyon.com/index/c...70/47/skaterpunk240sx wrote:could you post a link????????
In a 240? I'd like to see that vid. If anything that 240 prob looks more like a glob of cf than a 240.DrifterProdigy85 wrote:Its been converted and its accurate to 1-2mph more or less. Ill post a video of a 175mph sprint soon enough for you.
Glob of Carbon Fiber? Its fully stock looking, full interior. All it takes is power.Morph wrote:
it does not take that much power to go 175mph. you just have to have enough omph to overpower the wind resistance. top speed is determined by your gear ratio. did you change out your R&P?DrifterProdigy85 wrote:Gl
image removed from quote
do you really think it is safe to run 170mph+ on those goofy a$$ stock wheel and tire package. those tires look like 195 60 15. i dont even know of any z rated tires in that size. and i hope you were on a track. thats extremely sketchy nascar speeds on the streets.DrifterProdigy85 wrote:Gl
im not doubting that those speeds cant be hit, just that you didnt hit them. and until you show me a video, i find it incredibly hard to believe you took that coupe to those speeds.DrifterProdigy85 wrote:I guess nobody here saw the video of Enthalpys car doing 180+mph. Had stock rear and a 8000rpm redline. When i get a chance, ill be more than happy to post a high speed vid.
http://www.f-body.org/gears/
Put in 195/60-15 tire size, 4.083 Axle Ratio, .759 5th Gear, and 8000rpm Redline. What speeds do you come up with for 5th gear?
me neither.ILikeMy240sx wrote:I definitely wouldnt trust my car going over 150 miles per hour... LOL..
