what is wrong with my transmission? or is it my clutch?
plv
Car: 1989 Nissan 240sx SE
beginning last week, ive started having trouble shifting into 1st and 3rd gear. if i rev match though, they shift fine, so i thought my sincros were going bad or i needed transmission fluid or something. well its been getting worse and worse, sometimes i have to use an enormous force to get into a gear (any), yet sometimes they go in fine (i always have problems with 1st though).
so i thought this was bad enough.... today when i got off work i put the car in first gear (it goes in fine whe the car is off), press the clutch pedal ALL the way down and turn the car on, and the car started rolling forward slowly up the hill, as if the car had an auto transmission in it (WTF), and on the drive home the clutch felt really mushy. when i got home i got the car into 1st again, pressed the clutch all the way in, but this time the clutch acted normal and the car didnt move.
i dont know wtf is going on and this is pissing me off because this car has been very reliable and just now that i decide to sell it this happens. please help.
240marcuSX
Car: E34 525i
E46 M3
That sounds more like a clutch issue than anything else to me.
whitejamacan
Car: 91 240sx
should check to see if the master cylinder rod from the clutch pedal that goes threw the firewall if the rods movin like the jam nut isnt on... i had that happen before and it completly messed up my clutch
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
yeah, check for that and movement of the slave cyl on the transmission.
The rod on the slave should move out about an inch or so. This is the rod that pushes against the shift fork.
anywho, what i think is happening, is you blew a spring out of the clutch. I think it may be time for a clutch job, but check everyhting on the outside first.
oki-drifter
Car: 93 240sx fb
sounds like you're leaking clutch fluid(which is just brake fluid btw), if not a slave or mast cylinder problem
pr240sx
problemclutch does not dissengage completly
Check hydraulics and pedal adjustment, if not replace hydraulics.
InsanityInc
sounds like what happened when my clutch blew up. Well, mine got a little worse because one of the springs flew out and got lodged in the pressure plate after a while, at which point I couldn't depress the pedal at all.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
me and insanity had the exact same problem. not all that uncommon.
