justin1771pruner »
https://forums.nicoclub.com/justin1771pruner-u50774.html
Tue Nov 21, 2006 1:04 pm
my clutch pedal presses down to the floor and only kicks back about 5 or 6 inches then stops...if u pull it a littrle it will kick back to its fully extended position.while the car is on and clutch is pressed down to floor my shifter will not go into gear...it doesnt grind it just wont go in.....i checked the clutch master cylinder and its full.....there are no leaks and the pedal spring seems to be fine...what the hell is wrong with it?it is a 1989 nissan 240sx (hydraulic clutch)
