fontana dan wrote: ↑Sat Jun 08, 2024 2:17 pm
I'm a little bit confused on how that E-clip is giving you trouble so I went and took a picture of how mine is assembled.
How is the clip coming off? I don't recall it playing any part in the adjustment process. I think its there for assembly or something.
Here is the link to the pictures:
https://imgur.com/a/bwgZfZV
Thanks for that diagram. I printed it up long time ago and just seen it recently, but forgot where I put it. But I don’t need it anymore because all those numbers are useless except to the manufacturer lol. I’ve been able to get all my belts properly tensioned using the half inch maximum rule.
In my case, the air conditioning belt pulley has no adjustment bolt, just a pulley. It must have broke from the previous owners, and it’s impossible (I tried) to get a new one in without removing the whole damn compressor Mount assembly. However, I can brute strength push the pulley down just enough and tighten the pulley bolt: it works to give it about 1/2 inch of tension, but it’s not tight enough to prevent a little squeaking at cold startups or when the charge starts to runs low (that’s a whole other story, my $300 aftermarket compressor has been determined to have a shaft seal leak. I knew I should have spent double and went with Infiniti).
Anyhow: so, in your picture, the bolt is down incorrectly. How it’s supposed to be, that e-clip is supposed to seat in the first groove below the bolt head. And then you’re supposed to be able to wind it up. Otherwise, I think it risks sheering the bolt head or cracking the pulley assembly. I know it sounds dumb, but I have a chipped off power steering Mount, and a missing compressor bolt as a likely result of someone doing it incorrectly in the past. Once you have the tension right and torque the center pulley bolt, the e-clip and adjustment bolt don’t do anything. However, an old or bent eclip will not stay in place enough to adjust. It’ll just keep popping out or backing off.
However, I finally figured out a hack last night: with a new eclip, I used a cable tie to hold it against it. I could have wrapped some electric or silicone tape first to give it even further strength. That prevented the eclip from popping back and losing tension. Technically, that adjustment bolt should only go just to the outside of a couple threads beyond the hole. Then you tighten the pulley bolt, and it gets the belt tighter.
The waterpump belt is especially insidious and has given me trouble before. It really needs to be tighter than the alternator one because when that crankshaft spins at 1,500-2,000 first thing in the morning with the water pump, it’s unforgiving. But seems like I finally got it to quiet down and even with a wet cold belt, it’s not sounding like the neighborhood cats got sucked into the engine lol.
