What is trail braking??
ESPER
is it just mildly braking before a corner??
themadscientist
applying braking force late into a turn causing the rear to come out more.
MikeS14240sx
Car: 98 Nissan 240SX
ESPER
thanks guys
Pennyfreak
Car: Basketball and cars
there is an article in i beleive either sport rider or cycle world last month on trail braking and how to use it and do it. u might see if u can't find one. i have the copy. i will see if i can find it to see what it says. u might be able to go to there website and they might have that article available online. http://www.sportrider.com http://www.cycleworld.com
Nismo_Freak
Car: 89 Nissan 240SX
It helps to curb some understeer on the latter parts of a corner.
reggiegsd
Car: '94 Q, '73 240Z
Trail braking is lightly riding the brake as steer into the turn down to the apex. Some drivers use it to stabilize the car on a bumpy track. Normally its just used to go slow.
ESPER
well from the helpful article, it seems that trail braking is a far, far advanced technique that shaves seconds off yoru lap times........
pylon_boy
Car: Autocrossing
ESPER wrote:well from the helpful article, it seems that trail braking is a far, far advanced technique that shaves seconds off yoru lap times........
I wouldn't say it shaves seconds off lap times. Some good drivers choose to use it, some equally as good drivers choose not to use it. As stated above, it is mostly used to curb understeer in cars that do that alot. However, I will occasionally use it when I autocross as my car is only neutral when I am accelerating.
themadscientist
run pylon, RUN!!!!
reggiegsd
My Zcars always tended to be very neutral and any trail braking tended to overload the outside front tire resulting in some under steer. When I drove a friend’s Karman Ghia at a track event at Lime Rock, the only way I could get the outside front tire to contribute anything was with trail braking. I would think trail braking a front driver would be a disaster.
The stiffer the suspension, the less tolerant of trail braking the car will be.
For most tracks, in most cars, in most situations, trail braking won't work. There are always exceptions.
Most street cars have soft suspensions that have some allowance for trail braking built in. Most drivers, good and bad, instinctively use it.
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
Hey Reggie, Lime Rock is one of my favorite tracks. Big Bend is a great turn to trailbrake. I've done it countless times there. But I'm curious how that Karmen Ghia handled the uphill. I'm guessing it wasn't stock...
reggiegsd
This was the late '70s so you are right, the Ghias were pretty weak. Even a competative Ghia produced about 140 hp. Just not enough power to get into trouble on the uphill.
