I hope I am asking the right question here and this makes sense!
What is the total travel of the wheel on a 1995 Q45? The reason I ask is that I am experimenting with a wheel and tire combo that is:
1. Using 245/45-17 to get close (but not exact) to stock diameter on the stock 15" rim.
2. Low enough offset (30mm) that the tire just extends out enough to be below the fender. The outer edge of the tire is flush with the outer edge of the fender. This looks great, by the way!
This leaves about 2 to 2.5" of room above the tire to the edge of the metal when the car is resting on level round. I looked at the stock springs on the Q, and it looks like the spacing between the coils is lower than that (somewhere less than 1.5" or so).
Is this situation dangerous? Does the above spring coil measurement imply that the total travel on the wheel is about 2" or so? Will my tires touch the fender on bad bumps?
In driving so far, I cannot tell if it has touched the fender at all on bumps or highway dips, but I am worried that I may be in for a rude awakening! I'd like to get opinions from people on this so that I can decide if I want to keep this combination!
I'll try to take pictures if I can ...
Z
