What is this wire?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
So there is a blue wire with red stripe coming out of the engine side of the harness near the ECU. It is one of the thicker wires. On mine, this wire was cut, then soldered again. I cannot find this wire on the ECU plug, nor for the dash. Here is a pic of the wire. Again, this is coming out of the engine side of the harness. Anyone?
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
I think thats the wire that is holding time together. cut it, and the millenium bug will finally catch up to us.
c-rad
rexhunta wrote:I think thats the wire that is holding time together. cut it, and the millenium bug will finally catch up to us.
It is cut...
rexhunta
MY10 Forester X LE
sorry, early in the morning here :lol:
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
might be the earth for the coils...
c-rad
dattodude wrote:might be the earth for the coils...
Well, that is definitely the color of the 5th pin coming off the coil subharness... So I guess just run it to a ground?
dattodude
Sounds reasonable. I've only ever had 'chopped up looms'. lots of new wire. So I can't say for sure.
If you get continuity from this wire to the middle pin on each coil plug, then I was wrong..it's the 12V feed to coils.
See: http://shoeys.com/gallery2/alb...1.jpg
But it could still be an earth. Tell me what plugs it goes to in the engine bay, and we can figure it out.
