Meaux »
https://forums.nicoclub.com/meaux-u23660.html
Tue Mar 01, 2005 9:35 am
While trying to figure out how to unplug the IAC/ACC valve, I noticed that on the passenger side of the engine, above the valve cover, to the rear of the engine, next to the A/C component, there are 2 plugs. On the upper plug, there is a grey/blue wire. Apparantly over time, this wire has broken (from bieng stabbed by a butcher mechanic), and the grey/red wire next to it is still connected but shows where it has been stabbed also.
Jeeze.....I hope this has something to do with my high idle (1000rpm in N and P) Naw, I couldn't be that lucky, if not, how does the IAC/ACC unplug? I squeezed on the wire housing, but it dosen't want to give....Is the IAC/ACC adjustment screw viewed from the passenger side on the back of the valve?
Thanks...........
