What is this wire for ? Pic...
beans33
Car: 1993 ca18det 240sx
those are the two main plugs the white wire has a ground coming off of it... could this be the knock sensor
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
It's been a long time since I've had an original loom, but the only two shielded wires like that are for the oxygen sensor signal, and the knock sensor signal.
beans33
Yea i guess it is the knock sensor then, I really doubt the o2 sensor wire would be in the front corner of the car.
Secret squirrel
Car: 1990 240sx w/ ca18det
i thought knock sensor was a two wire sensor
SS
float_6969
Not on the CA, it's a single, shielded wire. And yes, that should be the wire for the knock sensor. There are actually 3 sheilded wires, the MAFS signal, the O2 Sensor signal, and the Knock Sensor signal. the Knock sensor signal is the only one that goes anywhere near the plug behind the battery.
rico05
Car: 1992 RMS13 w/ CA18DET
Yep. That is the knock sensor lead. Just in case you needed another vote, lol
float_6969
Dude, quite following me. You're like my post stalker...
