What is this under the oil filter?
AzBrewsky
Car: 95 Nissan 240SX KA24DE 5-Spd
See picture.. It looks like I am getting an oil leak from it.. What sensor plugs into this hole and is there a gasket for it??
crazeddingo
Oil Pressure Switch
98s14inaz
Car: 2010 Nissan Titan Quad Cab
They all leak. It needs to be metal on metal for it to work right too which is why it leaks.
ashibah83
Car: 93 SUPA BLACK COUPE
oil pressure sender, its pipe thread so put a little bit of teflon tape on it and call it a day
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
thay are right oil pressure sensor. but what weird bung is that between it and the oil filter mount? never seen it like that before.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
they leak when the diaphram for the pressure part ruptures inside the sending unit..its actually common for them to go out that way.....you need to replace it..as far as the deal under it..its for an after market gauge..
vancouverbc
Car: 1991 240sx
liquid_cool wrote:they leak when the diaphram for the pressure part ruptures inside the sending unit..its actually common for them to go out that way.....you need to replace it..as far as the deal under it..its for an after market gauge..
someone said they all leak because of bad design.
where the plastic plug meets the metal part.
Modified by vancouverbc at 11:31 AM 9/8/2009
locoluna825
Car: 90 240sx coupe
I have the same exact problem right now on my sohc i know its leaking from there because every time i lift the car up i wipe everything down and that still remains to stay wet with oil.
ive been searching for about an our now looking for what the hell this thing is called and i cant find anything, i went through courtesyparts, and few other part sites but nothing came up, also did a search on the site and i just found this. Oil Pressure Switch? thanks i needed to find this now i know the name of it.
deuce4Oh
Car: 1991 sil-camino,1985 AE86
It's a "T". Was the engine turbo before? It's used for an oil feed to the turbo.
