Somehow I can't find any other car that has the clip, then.Stoopcoupe wrote:It looks like a clip that keeps the brake pad secure
Thanks for the responses, guys. But I've got two conflicting answers. Is this an issue or a non-issue? If it is a problem, I'm not sure how I'd go about fixing it, haha!justeller wrote:http://www.rockauto.com/en/catalog/niss ... e+kit,1736
It is part of the hardware kit. It is a clip that helps hold the pad into the caliper bracket to cut back on noise and vibration. It basically a shim. Most higher quality pads will come with the hardware, or you can purchase separate. Def don't want it hanging half out though.
I'm afraid I don't know what "back in place" should look like, haha!justeller wrote:Just pull the wheel and pull the caliper and bracket and see if you can get it back in place.
Where does it pop back in to?horaciojr wrote:my ac had the same clip popped out so i popped it back in with some needle nose pliers
