what is this thing?
fullmetal
Car: 240sx, up for sale!!
what is this black thing and do i need it?
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Oil separator, and yes... Unless you like oil in your intake piping.
fullmetal
but it doesnt go to my intake lolone tube goes from the crank case to my intake with no oil seperator or catch can and the other side with this box goes to what looks like the trans almost. i will see where exactly when i finish pulling it apart to replace my exhaust gasket.
Seishuku
It should go from the crank case, to the tee on the valve cover, then from the valve cover to the intake pipe.
fullmetal
true that it does so that keeps the oil kicked up in the crank case from getting to the intake then? thanks for the help, now i just need a catch can cause my intake is coated in oil
