What is this thing?
240sxJoe91
Car: 1991 240sx Ka24de
Radiator has a crack in it...need to remove it so really quick...what is this black sponge looking thing? Is it ok to remove? I know its a stupid question but oh well....( not the drain tube ) here are two pics....Thanks guys...
AZ89two4Tsx
Yeah, it comes off easily. Don't worry about it.
nando
Car: 1995 nissan 240sx se
1989 nissan 240sx
just some foam padding. prob used to keep the radiator from vibrating on and/or hitting the rad support, it also seems to direct air tword the radiator and not letting the air escape over the top. i dont see a prob with just removing it. i got rid of it when i replaced my rad support.
240sxJoe91
Ok thanks dude...i appreciate it
J14cm7
Car: 95 240sx S14 SR20det
oh nando that hurts my eyes to look at. That thing looked clean to.
nando
1989 nissan 240sx
ha ha ya i know. shouldn,t be long till shes all better tho
sci2000tech
Car: '92 Nissan 240SX S13.5 RB20DET 'Vert
You can remove it, but I would keep it.
It helps direct air through the radiator(possibly among other things). You'd probably be fine without it, but the more air flowing through the radiator, the better.
zach-Ka
Car: 1990 240sx (SR)
sci2000tech wrote:You can remove it, but I would keep it.
It helps with cooling and makes it look a lot cleaner. I took mine off at first then replaced it with home door jam insulation.
hilux30
Car: 2007 Tacoma 4x4
It's there to soak-up fluids like beer that placed on the core support while your working, works great for coffee. Soaks blood too after you cut your self bumping into things in the bay.....
240sxJoe91
Yea ill probably end up getting a new one...or something to replace it...the one that was in my car is shot lol...sobbing wet.
