krash wrote:its on the positive side of everybody else's battery too. It powers things.
Mine is a factory-manny.krash wrote:Maybe its chassis specific? every s13 I've worked on has had that. It runs through the harness.
Edit: Scotty, was your car a/t from the factory or m/t from the factory? Now that I think about it, my friends kouki has that as well
yup, thats what I was thinking. My car has that (factory auto), my friends kouki has that (factory auto). You sure your car isn't a swap conno?scotty-2-forty wrote:Actually, Conno707 do you have an auto transmission? If so, I believe that to be the revolution sensor, inhibitor switch and a/t solenoid harness connectors.
Thank you sir.omgshawn wrote:That is correct
Mine no longer has that.krash wrote:its on the positive side of everybody else's battery too. It powers things.
My method tape the s*** out of it, then tuckILoveMyRHS13 wrote:Mine no longer has that.krash wrote:its on the positive side of everybody else's battery too. It powers things.
Because I got new terminals and cleaned all of that s*** up.
Yeah, used all new wires and did a grounding kit... Well, Keegan did, hahah.White Comet wrote:i ran those wires into a fuse and ran a single wire out the other side when i did my battery relocation. at least i think so, its been so long.
doug, did you just remove the red connector run those wires into the new terminal?
ILoveMyRHS13 wrote:Hurr durrs mine.
