What is this ?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
4wheelsoffury
Car: 1985 nissan 720 kingcab ST 4x4 2.4L Z24
I came across this dial a while back when I was running speaker wire, but I ignored it and forgot about it. It is some type of Pot with a notched rotation, I turned it a few clicks in either direction out of curiosity. It appears to be original, the only custom accessory are fog lights which have a toggle above my left knee. This thing is located in a gap above the right end of the junk tray that covers the blower on the passenger side.
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
Haven't the faintest idea. Nothing like that in my truck, but mine is a different sort of beast, '81 2wd (no ac or anything). Trace the wires and see where they go! I'm curious.
PEZi
nothing like that in my ST model
Aven
Car: 84 720 Kingcab
Got me on that one. I just had the dash out on mine and nothing like that on the passenger side. The only thing that even remotely sounds like it is the dimmer switch to the instrument cluster back light, and that doesn't look like that at all. Have to wonder if it wasn't part of someone's stereo system, either balance or fade sort of switch.
4wheelsoffury
I gutted all the radio stuff when I got it, so its not that. I was running new wires across to the right speaker when I noticed it, after work tomorrow I'll take off that tray again and trace the wires. The strangest thing about it that it seems to be original, but its in a weird spot and hidden. I have the 4x4 ST "sport truck" model, and mine was one of the last 720's made before the hardbody started that year, if that helps ?
Liquidnails
Car: Nissan Maxima
It's most definitely for a Stun Ray of some sort. That pot is probably for setting the intensity. Maybe there's an activation switch or button hidden somewhere else?
4wheelsoffury
My investigation has given me more questions than answers, on the rear of the dial it has a bare metal solid wire (looks like a temp probe) coming out and disappearing behing the heater core, there is also 2 blue wires. One of these blue wires also disappears behind the heater, and the other is connected into a black factory harness in front of the blower. It may be worth mentioning that my AC was converted to r-134 before I got the truck, but I still have no idea what the hell this dial is doing there !
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Looks like a temp control switch. But not an auto type. It looks like one on the water heater in the boat I work on. Thats strange.
moredunes720
Car: 1985 nissan 720 4x4
maybe a timer of some sort for the cab light? Nothing like it in my '85 4x4 either, though, at least that I ever noticed when I took the dash off.
dogred
Car: 1983 D720
Maybe it is the thermostast for the cab!
4wheelsoffury
At this point, its down to :1 : I dont know and dont touch it2: Its the thrust level for the rocket assist module
Return to “Datsun 720”
