what is this
johnnyappleseed
Car: s14 240sx with s13 sr20det
i just got my megan racing track coilovers and with the allen keys and the adjustment tool it has like 2 washers in it. what are those for?
Modified by johnnyappleseed at 11:24 PM 3/7/2009
themadscientist
wecanhazpic?
johnnyappleseed
if you look at this thread look in the bag with the adjustment tools and the two washers or rings.
zerothread/284376
johnnyappleseed
anything that can help?
94_240sx
Car: 94_240SX
All I can think of is rear lower mounting points. Maybe they go there? I'm curious too.
White Comet
Car: fc, s13 and mazda6, Sierra
im frsport and ask
johnnyappleseed
White Comet wrote:im frsport and ask
i was seeing if anyone with megan coilovers would new so i could get a answer quick so i could put them on
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
Dude it should be obvious as to what they are for. The allen keys are for you so you don't have to buy some to adjust your camber plates on the front shocks.
The half circular ones are for lowering/raising the shock itself. There are silver washersORnuts with the squares on them below each spring. You can use those to tighten the washers/nuts together so once you lower it to the desired location the spring will not move and change ride height on you.
The little washers probably go on the bottom ball joint of the rear struts to space them out so the stock bolt can tighten it snug. If not, I'm not totally sure.
Either way man, you are good to get started and install these. Those tools can be used to adjust when they're installed! GL
White Comet
it took a day and a half to get an answer on here, im'ing frsport would have been faster
