itsnever2fast »
https://forums.nicoclub.com/itsnever2fast-u43601.html
Sun Mar 18, 2007 4:53 pm
umm... thats just a single prong diagnostic plug in connector... that one with the yellow wire with red stripe is just a tach signal wire.... when i did my custom harnes i just clipped thedamn thing off at the ecu, and connected it from the ecu block to the dash connector... it is a goofy design but the wire actually heads out toward the engine bay and splits and heads back toward the ecu and goes up the dash wiring, so when you omit this wire you have to connect the dash block directly to the blue ecu block. you do NOT need it to head out to the engine bay. mine works fine. dang i wish i took pictures of my wiring process
