what is this???????????
blackbeltclub99
Car: 93 RX7
I found this on my s13 front clip. I was wondering if anyone knew what it is.
blackbeltclub99
Car: 93 RX7
here is another pic?
thekage
Car: 98 Dodge Caravan
98 Dodge Intrepid
looks like a manual boost controller maybe??
blackbeltclub99
Car: 93 RX7
It is a Nissan part. with an electrical conection on top and the black spin knob will spin either direction without a stopping point.
I thought Manual boost controler at first but i really don't think so now.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
It's probably the oem boost pressure sensor if it came off your clip.
blackbeltclub99
Car: 93 RX7
any way to use it? is there a warning light or an oem boost gauge or something? Or does it just send a signal to the ECU?
justmerging
it just sends a signal to the ecu. it's not needed in the swap. you can just run a vacuum line straight to your wastegate.
