What is this sound?
raven69david
Car: 2002 Infiniti Q45
I am uncertain what this sound is once the car shuts off. :wtf2:
https://www.youtube.com/shorts/euGwoizI4K8
macgiver
The short time the engine able to run sounds terrible , and has the bad noises running , and running-on after seems to have same sick noises . Getting the car running ' smooth ' again probly comes first , parts needed there may be the cure-all ?
Rubber hose as stethoscope can pinpoint noises . A stethoscope can pinpoint noises :rotflmao better?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
macgiver wrote:
Wed Jan 05, 2022 5:26 pm
Yep, +1. Sounds like it's building up pressure someplace it shouldn't be, then venting it after it stalls. Figure out why it's running crappy and the noise will probably fix itself.
macgiver
Ya better probly get to the " problem behind the problem " , or soon , it'll be The SOUND of SILENCE :tisk:
HELLO DARKNESS MY OLD FRIEND......... :rotflmao
EniGmA1987
Car: '06 Infiniti M35 Sport
I would look up a diagram of your hoses and make sure everything is routed properly for your PCV system, replace your PCV valve, then check on the wiring to all spark plugs and coil packs, and take a look at all of your spark plugs to ensure none are fouled up.
VStar650CL
Technical Expert
Honestly, that sounds like the crankcase getting pressurized by bad stem seals, cracked rings, or something along those lines. I think I'd make sure it has compression before looking at any of the plumbing.
raven69david
It was the powering steering hose that’s pinched. Glad it was nothing serious.
EniGmA1987
raven69david wrote:
Thu Jan 06, 2022 11:16 am
And un-pinching that hose solved the engine stalling issue?
raven69david
EniGmA1987 wrote:
Thu Jan 06, 2022 4:22 pm
No. The stalling seems to be a timing issue. I’ll have my mechanic fully diagnose it and figure out what’s causing that as soon as he has time.
EdBwoy
Is this vehicle new to you or have you been driving it when these issues suddenly appeared?
I'll be back in for updates, this is interesting.
raven69david
EdBwoy wrote:
Fri Jan 07, 2022 12:25 pm
I bought this car about a month ago for $1000. I knew it had problems but didn’t mind a project car. The kid who had it before me didn’t take good care of it and he stated it was in limp mode. The secondary cats were stolen and O2 sensors were damaged. I replaced the missing cats and added new O2 sensors. I’ve also replaced the old crankshaft and camshaft sensors. I’ve also replaced the throttle assembly for the throttle position sensor as the car dies as soon as you press the pedal. I believe it’s a timing issue based on what the engine sounds like. Next I plan to replace the VVT solenoids but only after I’ve confirmed it’s a timing issue.
I have a mechanic that will do all the heavy lifting for me but since he’s been busy, I’ve tried to do what I could in the meantime.
BTW, I’ve watched all your videos and have learned how to repair my own M’s with them. Thank you for all you’ve done. You’re the king of info for all of us here.
raven69david
P.S. I cannot scan for codes as I get an error message that the ECM is not found. I have power to the DLC and all fuses are good, including IPDM. It’s most likely a loose ground or wire connected to the DLC which I cannot check since I don’t have a multimeter. I also have no control to climate control or radio so that leads me to believe something electronic is not connected properly as the previous owner did a lot of tinkering with the car blindly without knowing what he was doing.
VStar650CL
Technical Expert
The ignition and battery fuses to the DLC share nothing in common, so your hunch about it being a ground issue is probably right. You can find the DLC layout here on Pg 605:
https://www.nicoclub.com/service-manual ... 2%2Fec.pdf
Both the Black pin 4 and Black/White pin 5 wires need ground. A meter isn't the best tool to check it, use a bulb-type test lamp. Putting the gator lead of the lamp on the ground pin instead of the chassis verifies the ground wire, if it will light the lamp normally then it has enough ground for your scanner to work. So going between the Batt (7,16) and Ignition (8) wires and the DLC grounds on 4-5 verifies the the entire power circuit on both sides.
raven69david
Did a little investigating and pulled all the plugs.
VStar650CL
Technical Expert
That has to be an injector issue. If we call the lower left #1, then #2 is lean, #5 and #6 are rich, and #4, #7 and #8 are all b_tch-rich.
raven69david
VStar650CL wrote:
Sun Jan 09, 2022 5:52 pm
Yep they’re pretty bad. #1 has a burnt coil that seems to be caused by a bad ground in the harness. The rest are bad due to what seems as a bad valve cover gasket that was replaced but plugs weren’t.
