The part that sprunk a leak is the metal pipe which i believe is pressed into the intake manifold. I would have to remove or replace the entire intake manifold. I dont care if the intake runs a little hotter. this is my beater car but i need it to get from a to bhellzknight wrote:why not just replace the line?
Ive never seen that line caped off before. I think its required for the cooling system
Its off to the side where it connects to the hose. Its not easy to get to.hellzknight wrote:ooh the metal part sprung the leak? where? infront of the intake or towards the back? you might be able to get away with welding it :x
+1 for jb welding itzerepdivad wrote:as cracked out as it sounds jb weld it maybe??
