Pathofinder wrote:or do it more professionally
To do the wiring more solidly, you'd have to get a spool of 14 gauge wire, some female and male quick disconnects, a soldering tool, some solder, electrical tape, and heatshrink tubing. You can obtain the wire, quick disconnects, and heatshrink for very cheap at Harbor Freight tools, and a relatively decent soldering tool, solder, and tape at Radio Shack. Strip some of the wire, place some heatshrink tubing on the wire, then crimp on the necessary quick disconnect, solder it on, wrap some electrical tape around the connection, then slide the heatshrink over the tape and shrink it. The cost for all this might be $35 - the most expensive part would be a soldering tool. Though the better option would be to remove this hackjob instead of throwing money at it just to keep the hack working, but we're not having much luck with that so far unfortunately.
