lag »
https://forums.nicoclub.com/lag-u50586.html
Mon Nov 13, 2006 2:43 pm
Okay skippy, I thought the valve beside the one pointed out was the IAC and figured the other was a compensator of some sort. This valve is to small to take care of the air requirements of an engine idling.
Carl says it's the fcid... and again (read the post as I already searched before I asked the question) I don't get an answer to the question by searching for fcid or IAC.
If I do need it, not running AC, is there a USDM part that can replace it.
I also looked through the FSM and maybe I missed it but didn’t see labeled on any of the diagrams.
Seriously thanks for the help, and it’s not always a good assumption to believe that because someone has 1 post or is new to the forum that we’re clueless. Most all, if not all, auto forums work the same so it’s nothing new. Just my first time needing to use this forum. And yes I did expect a response like yours and no I’m not hurt… Usually what I’ll do if I tell someone to search that already stated that they searched is to try it myself and if I get the answer give them the search terms to help them along.
Again, thank you.
