What is this plug under my water pump?
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
I think this thing might have been leaking... or maybe the water pump was leaking onto it giving an illusion that it was leaking. What is this?!?!?!
EnjoiNismo
Car: 93 240sx
Im not a 100% sure, so dont' quote me, but i would be that would be a drain plug.
OM3GA
Im pretty sure it is a drain plug for coolant, but i thought it was leaking so we tried to take it out but it will not break free so im scared lol. I dont think it moved at all but now im paranoid that we even tried to loosen it i feel like it could cause problems
prtrillaboss
my car is down from leak from same spot. even with my new water pump and seal. I cant remove it either, well with all the dif type tool bits nothing fits right an dont want to strip it out. My car down for 2 week now anyone got advice?
Show us a pic of the mating surface of the water pump.
I don't think that plug is leaking. I think it was coming from the pump, as the mating surfaces in that area are really not very good (from what I can tell via pics).
prtrillaboss
I seen that plug leak on mine with new sealent on water pump. do you know how to remove the plug?
Nope.
I'd clean it real good with a wirewheel on a drill and some brake cleaner and smear some JB Weld around it.
Seriously.
I did that on a freeze plug on my old Q45, since replacing it would have meant pulling the engine. Held up for 7 years.
prtrillaboss
I even ask nissan tech and he didnt know. I thought about doing gasket sealer over it but that not work long term. Did you use aluminum type jb stuff?
OM3GA
Im for sure not doing any type of JB weld at all, This engine is costing me $7000 and ill sell everything before i run JB weld on there lol, I want to do this right but i have no idea what to do to get that thing out or if that things even leaking. How can it leak it its so damn tight? Right?
prtrillaboss
OM3GA wrote:How can it leak it its so damn tight? Right?
I think its the spaces between threads I don't want to jb either.
