What is this plug on the sr20det harness??
redsx13
Car: 93 240sx 03 350z
japslapsilvia
Car: 90 s-13
they are check connecters. Yellow one is Tach signal and Red is comming from IIRC Ignitor...they arent really used.
DatsunDimer
Car: 1972 Datsun 510
Sorry to semi-hijack this thread. Could someone tell me exactly what/where the "battery connectors" in the first pic are for? Obviously have a Datsun so I need to figure out what to do with those plugs. Tried searching and asking around but haven't gotten any help. Thanks.
redsx13
DatsunDimer wrote:Sorry to semi-hijack this thread. Could someone tell me exactly what/where the "battery connectors" in the first pic are for? Obviously have a Datsun so I need to figure out what to do with those plugs. Tried searching and asking around but haven't gotten any help. Thanks.
Thoes plugs connect to the (outer) chissis harness. SR20 will have 3 plugs there, KA will have 2. wire functions are as follows
SR Wire Color -----KA Wire -----Color Function
Black / Pink stripe ----- Black / Pink stripe ----- Fuel pump relay Green / Orange stripe----- Green / Orange stripe ----- Transmission neutral switch Red / Black stripe ----- Red / Black stripe ----- ECU relay Green / Yellow stripe ----- Green / Yellow stripe----- AC relay Black / White stripe ----- Black / White stripe ----- ECU power Blue / Green stripe ----- Blue / Green stripe ----- AC relay Black / Yellow stripe ----- Black / Yellow stripe ----- Idle air control solenoid power Brown -----none ----- O2 sensor power Red -----Red -----ECU backup power Black / Red & Blue / Red----- Black / Red stripe ----- Main ignition power
